Image stored in VI - large filesize
I am using Labview with the Vision Developement module. In one of my projects I have an Image Display element on the frontpanel. Whenever I open the VI, an old image is shown in the Image Display. I have no idea how it was stored there in the first place. Unfortunately it's a very large image, resulting in my VI being larger than 500MB...
Is there a simple way to get rid of the Image?
Thanks.
(2,811 Views)
You probably made that image default at some point.
So clear it somehow (from the program or maybe there's a right click option to do it). Then right-click "Data Operations>Make Current Value Default" or select it and use the VI's menu "Edit>Make Selected Values Default".
(2,807 Views)
I suppose you're talking about a picture control?
Have you tried right-click>earase first ?
(2,755 Views)
