Imaq usb palet doesn't appear
Hi all,
Are anybody maybe encounter with problem after installation of imaq usb driver, the usb imaq palet doesn't appear 😞
Outside the Labview I succeed to connect by Vision Assistant but in VI Vision Assistant doesn't see usb  camera.
Thank you in advance fore help.
Yan
(2,909 Views)
Hi Yan,
This happened to me also. I have two versions of LabView, 8.5.1 activated and 8.6 Evaluation. I installed the driver like three times but I only tried with LabView 8.6 and no palet appeared. Finally, i tried in 8.5.1 activated and it was fine and working properly. If you have more than one version of LabView, my advice is to check them all and see in which one the palet is visible. Other than that, i can't really think of anything else.
Hope this helps,
Sabin
(2,892 Views)
Hi Sabin,
Thank you very much for your help.
I found workarround.
http://digital.ni.com/public.nsf/allkb/EA16CA6E1A6D3046862574AA007584E2
BR
Yan
(2,888 Views)
