Imaq usb properties page problem
hey,
i a live acquistion taking frames, im subtracting a mask image for each acquired image. i have a properties page for the acquiring images(used to change the resoution of the image)this is in a case structure, but i need the same changes to be applied in the mask image aswell. i have an image write\read system set up so that the first image acquired in asequence automatically goes in as the mask(the image write VI is in a case structure).any solutions? see code attached. cheers.
(2,552 Views)
Brendon, can you not use the resample vi to adjust the resolution of the mask.
Hope this helps.
Kind Regards
Steven Bird
(2,530 Views)
