Immediate Load Config
Hi xseadog,
I was able to modify 'hp8133 pulse channel action.vi' and set the duty cycle based on the FP input. Basicially, the default setting for 'Hold' was changed from width to Dcycle.
Could you please take a look at the 'pulse amp' connection in "Hp8133A Application Function.vi?" All other settings are working ok, except, this one....( I checked the voltage.vi and it looks okay, but does not work)
Thanks a bunch!
Message 41 of 42
(846 Views)
Hi Jjlee
check the attached file
you appear to still have a problem with duty cycle !
I can see that you have adjusted your frequency - now 1 Ghz
Have you attempted to manually adjust settings ?
I mean if you can do that then why don't you save the parameters in a memory register and call as needed ?
xseadog
Message 42 of 42
(841 Views)
