Impedance Analyzer Sweep
I'm trying to automate the data acquisition (frequency sweep) for two parameters over the range of frequency (10 Hz to 2 MHz) with time using iET labs 7600 plus precision LCR meter. We will be using LabView and I was wondering if anyone has a sample code or an idea from where to start for a beginner.
https://www.ietlabs.com/7600-lcr-meter.html
So in summary we are trying to automate the process of logging the sweep of two parameters (R and X) over the range of frequency using time step i.e. every 1 or 2 minutes for a period of 24 hours or couple of days.
Thank you,
(1,498 Views)
Their website has an example LabVIEW program - https://www.ietlabs.com/Drivers/7600_LabView.zip
Have you tried that?  If you are stuck somewhere post your code for help.
Craig
(1,429 Views)
