Implement digital logics in LabVIEW
Could you please help me to implemnet this logic in LabVIEW.
Let's say my number is           101011010     and I have to XOR it based on MSB with 1001
In each step I move right 1 bit and if MSB =1 I have to XOR it with 10001 and if MSB=0 I should do nothing
1   0   1   0   1     1       0        1        0                ( if MSB=1 do XOR )
XOR
1  0    0   0    1
0  | 0    1   0    0     1                                       1 bit right shift  then MSB=0 so do nothing
      1   0    0    0     1
       0 |  1    0   0      1      0                              1 bit right shift   , MSB =1 so XOR
             1    0    0      0     1
             0  | 0    0      1     1     1                               ( MSB =0  so  do nothing  )
                    1    0      0     0     1
                    0    0      1      1     1     0
(3,810 Views)
Why don't you try it yourself and if you run into problems, show us what you have so we can help you out?  We shouldn't be the first resource you use.  YOU should be the first resource.
Bill
CLD
(Mid-Level minion.)
(3,785 Views)
How are you storing your number?  U16?  Boolean Array?
(3,746 Views)
