Implement switching circuit in labview
I fail to see why you cannot provide the interface to your board. I fail to see why you cannot provide details on the exact example you are using. I fail to see why you cannot perform the control of the digital I/O in MAX - by far the simplest of all hardware control. With a. DAQmx Write or DAQ Assistant, you only have to write a true/false or 1/0.
Tirmizi,
Your mention of a feedback circuit makes no sense at all.
Message 21 of 31
(977 Views)
i just want to clarify on what basis he want to either just make switching or on some measurement conditions
Message 22 of 31
(970 Views)
The whole thread is about controlling some relays and numerous statements have been made the incomplete schematic. Your attachment of the same incomplete schematic and not mentioning that, the poster's refusal to attach the full schematic, both make no sense.
Message 23 of 31
(959 Views)
Hi Tirmizi
Frankly speaking I dont have the circuit right now...... I have to built it. My project is in development phase right now..... I dont need the switches S4 and S5. Presently I need to develope a VI which could automate the switching of relays, later on i need to go for the hardware design......... The circuit which i have posted was nothing related to labview i guess.......i just need to control the switches in the circuit using relays and the switching must be done automatically.......... So I am looking for few suggestions on how to automate the swiching process of the relays......
Regards
Pratheek
Message 24 of 31
(955 Views)
You've gotten suggestions. Have you tested the 6501 in MAX? Have you taken s single tutorial? Have you tried the DAQ Assistant with a single digital output? Don't just say nothing works without providing details like error codes/messages. Do use a dmm when testing.
Message 25 of 31
(948 Views)
for automation of relays you should defined some conditions in your vi basis on which your relay will automatically get switched. like if your voltage at certain node reached 15 V then switch relay 1 to OFF/ON, and similarly for other relays.
Message 26 of 31
(935 Views)
The simplest example that comes with LabVIEW is called Write Digital Port. That has everything you need to get started.
Message 27 of 31
(932 Views)
I am sorry. You are talking about testing the devices and i am requesting for suggestions in developing a graphical programme to control the relays. I dont have any hardware right now for testing......The attachment is almost the same but the complete over view of my project
Message 28 of 31
(925 Views)
Thanks alot
Message 29 of 31
(921 Views)
The only hardware you need for testing is the 6501 and I have yet to see any evidence that you have tried anything to learn how to use it.
Message 30 of 31
(915 Views)
