Implementation of an Array of Clusters in CVI ??
I'm using CVI to make several DLL's to be used in Labview. I have an array of a cluster of three numeric data types, in other words;
typedef struct
uInt32 Wavelength;
float64 Power;
float64 OSNR;
} Data;
typedef struct
int32 dimSize;
Data peakData[1];
} DataArray;
typedef DataArray **DataArrayHandle;
This is the first time I've worked with a struct within an array in CVI, and I'm a bit confused. I have read the tblsrch.c example in Labview and I am now thoroughly confused.
I understand having to resize the array, then setting the dimension size, then allocating memory for the new Data struct. But I can't seem to figure out how to write to the Data struct member data w
/o having labview crash.
Can you provide an example of how to write to say, the Power Data member? I'm just flumoxed here.
Kindest,
Warren
(2,841 Views)
Just in case you don't get the right CVI answer here in Labview General, try the CVI link too - its probably more related to your Q.
Good Luck, Doug
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=8&RFORMNUMBER=2&RHIDETAG=TRUE&UCATEGORY_0=_46&UCATEGORY_S=0
(2,841 Views)
Hi Doug,
My question pertains to the proper use of Labview data types and structures. I believe your assessment may be incorrect. Thanks for the advice.
Kindest,
Warren
(2,841 Views)
Sorry 'bout that - see my new answer - so I could attach a file.
Doug
(2,841 Views)
Warren,
See if the attached fits in any way.
I began with an Array of Clusters, then unbundled the Cluster to access an element. Then added a new value (for Power) of one of the elements. Index the array and replaced that cluster and outputted a final array.
To run it, enter a value for the new Power (eg 5) and choose an index (eg 1). Also, put some fake numbers in the original Array so you can see the change.
Hope this shows some of the manipulations you have to go through. Good Luck, Doug
(2,841 Views)
