Implementing Tiny Encryption Algorithm, trouble with string to byte to unsigned 32 conversions based on my understanding of C source code.
I am working to implement the Tiny Encryption Algorithm. I have attached work in progress. In C (attached code) the algorithm takes an unsigned long section of the text input and encrypts it. I am trying to use the string to byte array and then process 4 bytes at a time of type U32 in a for loop. I do not know how to represent the 4 ascii bytes as an usigned 32 bit integer. Please look at the VI work in progress. Would appreciate any explanation as to how to access the data in a loop/how to implement C algorithm in Labview.
Thanks.
(4,598 Views)
Just typecast your string into an U32 Array (Pad first if string size is not a multiple of four). The rest will fall into place.
See attached example.
(4,598 Views)
Hi Bernie;
I succesfully implemented the TEA algorithm in LabVIEW and is part of the Crypto-G library. For more information about Crypto-G, check http://www.visecurity.com/cryptg.shtml
Regards;
Enrique
www.visecurity.com
www.vartortech.com
(4,598 Views)
Thanks for the help, problem solved.
(4,598 Views)
