Import C# DLL into LabVIEW
I'm using LabVIEW 2024 Q1 (32-bit) and trying to import a C# DLL into my LabVIEW VI. However, I'm encountering an error message stating "An error occured trying to load the assembly." I've attempted to import other DLLs as well, but the same error persists.
(1,756 Views)
The first suggestion is to check bittness — obviously you can't load 64 bit assembly into 32.bit LabVIEW and visa versa. Or share source code.
(1,748 Views)
Accepted by topic author ayox
(1,712 Views)
