Import .CSV files into Excel workbook using ActiveX
How can I use ActiveX to import a .CSV file into an Excel workbook, in a manner similar to using the Data -> Import External Data -> Import Data -> Select Data Source, etc., which will then bring up the Text Import Wizard, allowing data to be formatted into separate columns based on specific delimiters?
(3,798 Views)
This question was a little more difficult than I first anticipated. I have created an example that uses .AddQueryDef to a sheet. Take a look at the example and let me know if you have any more questions.
(3,798 Views)
I am sorry I attached the incorrect file. Here it is.
Allan S.
Applications Engineering
(3,798 Views)
Can I get this in version 6.1? Haven't upgraded to 7 yet. Thanks.
(3,798 Views)
Sorry for the delay here is the version you requested.
(3,798 Views)
