11-04-2005 11:00 AM
11-07-2005 05:23 PM
11-08-2005 10:35 AM
11-08-2005 10:52 AM
What I meant was I use LV8.0. and I have problem converting CVI instrument drive to labview VIsin 8.0 which worked fine in 7.1.
So if I use built in conversion program in 7.1 it works fine and generates all vis for every funstion in instrument driver.
As I wrote these are just plain c functions without and instrument interface.
I tried both modes in 8.0 Basic and advanced.
11-08-2005 02:46 PM
11-08-2005 03:58 PM
11-23-2005 07:52 AM
11-23-2005 12:21 PM
I downloaded DriverCtoL.exe from ftp.ni.com. I forget where exactly I got it and I can’t find it again. I run the program and it installs the tool/convert cvi to vi command. When I run the command and find the 2533.fp file it asks for, I get and error message.
“Error -43990 occurred at Not a valid function panel file.
Verify that the function panel file is valid and attempt the conversion again.”
Is there another way to convert the cvi to vi? Or, what step am I doing wrong?
11-23-2005 12:56 PM
11-23-2005 01:58 PM
