Import/.Net Controls to Palette... ERROR
I import picusbnut.exe, but error as the following.  How do I solve the problem?
(3,616 Views)
Hi somchai,
Do you have the .NET Framework 1.1 Service Pack 1 or later installed?  Can you import other .NET controls, particularly from the System.Windows.Forms assembly?
Jennifer R.
(3,587 Views)
Hi Jennifer R,
   I have .NET Framework 1.1 Service Pack 1 or later installed.   I have another .NET controls, but I can not test it because the test has to be on Microsoft Windows Vista.  Would you mind testing it and letting me know?
somchai_ss@hotmail.com
(3,571 Views)
Hi somchai,
I tested the PicWinUSB control on a Vista machine and the same error occurred.  Did you say you have been able to successfully import other .NET controls?  For example, can you import the "Button" from Systems.Windows.Forms?
James R.
(3,554 Views)
Dear Jame,
   Thank you for your test.  I have never successfully imported any .Net to Labview.  Why can't every .Net application import to Labview?
(3,545 Views)
Hi somchai,
It appears the exceptions with these .NET applications occurred outside the LabVIEW environment, within Systems.Windows.Forms.  In this case, LabVIEW simply passed on the error message.
James R.
(3,522 Views)
