Import Web Services into LabVIEW with available WSDL file
I am NEW to the development of LabVIEW solutions using Web services/Networing protocols.
I have a WSDL file which has set of methods supported. I would like to import those methods as labVIEW wrapper VIs and
use to query and get the data from the web services hosted by Web Server.
I have gone through the tools->Import-> Web Service option in LabVIEW, But it is asking only the WSDL URL, where as i have wsdl file only.
Please let me know if i need to look out for any other information.
Prakash
(5,344 Views)
Hi Prakash,
The following link might help you with your problem:
http://forums.ni.com/t5/LabVIEW/How-to-import-WSDL-file-into-LabView-8-6/td-p/1063387
Cheers,
Cerati
(5,340 Views)
Sorry.
I did not get this post while i am searching for.
Thank you for redirecting me.
The WSDL file needs to be hosted by the web server. It seems we can not use simple wsdl file stored on local drive to import the web services into LabVIEW VIs
Prakash
(5,338 Views)
