Import image to labVIEW from MSSQL
Dear all ,
     i have some trouble about import the image from the SQL server by using labview
database connectivity toolset . How can i read the image in the Database ? as the image
is encoded by binary.
Thank all
(4,151 Views)
Hi shingy,
you should store it temporary on your harddisk. You can load it from there with the "normal" Picture functions.
Which format has your image?
Mike
(4,128 Views)
hi mike ,
        in fact , i want to import the image to the labview  from the SQL database , but the image datatype is varbinary( Max ) ,
i don;t know how i can show this image and show it in the labview after i use database connectivity toolset to get the information of this image
my image is jpg.
is there any demo to do this ?
(4,124 Views)
Hi shingy,
you can read image from the database and store it to a file. You should be able to read the data like all other entries from the database. Store it as *.jpg and load it with "read jpg file.vi".
Mike
(4,122 Views)
