Importing Instruments Driver from LabWindows/CVI
Does anybody have got wintools_32.dll library ?
I need it to convert LabWindowc/CVI Wintools Instrument Driver to Labview.
Could you send it to me?
Romek.
romekn@poczta.onet.pl
(3,456 Views)
I'm not sure what this DLL is that you're referring to. I have LabVIEW and CVI both installed on my machine and do not have this DLL. I also searched on Google and there were no listings for this DLL. What software does this DLL come with and why are you needing it? Have you tried using Tools>>Instrumentation>>Import CVI Instrument Driver?
J.R. Allen
(3,456 Views)
Hi!
Thanks for your answer.
Exactly, I've tried to import LabWindows/CVI instrument driver to Labview.
This Instrument driver I've found here:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3F04956A4E034080020E74861&p_node=DZ52176&p_submitted=N&p_rank=&p_answer=&p_source=External
During import procedure i was asked about wintools_32.dll library.
Personally I am interested in System Tray icons functionality of this driver.
I'm not sure that wintools_32.dll is Labwindows/CVI library, but i've searched Microsoft Windows pages with no results.
Regards.
Romek.
(3,456 Views)
It is a CVI instrument driver but it is not a plug and play driver so you can't use the import function in LabVIEW. Someone with CVI needs to to create the DLL from the source code in the zip. You might want to post to the CVI forum and check with the folks there.
(3,456 Views)
