Importing Shared Library
I am attempting to import DLL libraries that contain functions for a 2-port FastComm RS-422 Serial card. I am able to import all of the functions in the libary except the Read and Write functions. I was able to get past some of the warnings that I was missing header files by adding the paths to these headers files to the include paths list. I am now at a point where the wizard is telling me that the two functions (read and write) are not recognized because there are undefined symbols and I may need to add preprocessor definitions. I have also tried to bypass the wizard and use Call Library Function property nodes with no luck. I have attached two screen shots of the warnings I am getting. I really need to get these serial cards to work. The reason I am using the dll files instead of visa is that I was unable to get a baud rate above 230400 using visa and I need to get up to 1.2 Mbps. These cards can handle well over that so I am trying to use some of the asynchronous functionality of the cards with the provided DLLs.
(3,848 Views)
Please attach the header file(s). There's nothing we can do from truncated errors in screenshots.
(3,825 Views)
Sorry. Here you are. I can't attach the DLL file so I attached the source code. Thanks!
(3,814 Views)
I figured it out. I needed to install the Windows SDK 7.1 and Visual Studio 10 header files. Thank you for your response.
(3,796 Views)
