Importing data from text file to ring control.
Is there a way to import data to a text ring control with labview.
I would like to put in many register definitions into ring controls but manual input would take a lot of time.
Was wondering if there was more of an automated way I could read the values in from a file.
Jim
(4,891 Views)
Yes you can do it
LabVIEW 2012
(4,888 Views)
Or like this if you have a control name on each line.
Ben64
(4,884 Views)
(4,882 Views)
Accepted by topic author Jim_Glanz
Using the first method gives you the ability to extend it such that each column specifies a ring control if you need to populate multiple rings.
This example assumes that all three rings contain the same number of elements. If not you will need to create a subVI that removes empty elements. [Edit - create a text file that contains a column for each ring separated by a tab.\
LabVIEW 2012
(4,876 Views)
