Importing labview code into labwindows
Hi all,
I have the code devloped using labview evaluation version and the code runs nearly 15 files connected and now there is a requirement to change over to labwindows 7.1 full vesion? can any one suggest me to come out of this problem? I am new to both these fileds.
thanks
Jagadeesh Raju
(2,900 Views)
If you have the application builder, you can build your VIs into a DLL. You can then call that DLL in LabWindows/CVI. If you don't have the application builder, maybe you can find someone who does.
I have to ask though, why the change after the work has begun?
hope that this helps,
Bob Young
(2,886 Views)
Bob,
This is a duplicate thread (with the same name). There has been a fair amount of dialog with him on this subject on the other thread, pretty much the path you are suggesting.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,883 Views)
