Impossible d'ajouter des curseurs sur mon graphe déroulant
Thanks, it worked!
Do you know if it's possible to have to have the "get time" function as the x axis of the graph?
Message 11 of 18
(471 Views)
Hi Alex,
  • You could use waveforms and use their included timestamp for X axis.
  • You could set the offset/scaling of the X axis to match your expected timestamp scale.
Why don't you apply the same property to the graph as is already used for your chart?
Message 12 of 18
(462 Views)
I tried to use the same property node as the chart but I get a big number and not the date and time.
Message 13 of 18
(460 Views)
Accepted by topic author Alexb91
Hi Alex,
Because you forgot to edit the formatting of the X axis!
Change it's DisplayFormat (in the graph properties) to "absolute time"…
Message 14 of 18
(454 Views)
Right click on X scale : "Formatting...".
Select "Absolute time".
Message 15 of 18
(453 Views)
Thanks!
Is there any way I can also get the date to show on the graph?
Message 16 of 18
(448 Views)
My bad I found it in the properties!
Message 17 of 18
(446 Views)
Thanks!
Message 18 of 18
(428 Views)
