Impossible to build application (copy lvanlys)
Early in the build process I get an error message (see below). I did click the run button with key combination to force recompile and saved all before trying again: it doesn't help. The same code builds well with Labview 8.20 on Windows XP, so I conclude the problem originates from Labview 8.20 for Mac. Any clue???
Error message:
The build was unsuccessful.
Possible reasons:
Error copying files.
Source: OSX:Applications:National Instruments:LabVIEW 8.2:resource:lvanlys.framework
Destination: Docs:icohen:Desktop:Spikoscope_source_820:bin:SpikoscopeMac:Spikoscope.app:Support:lvanlys.framework
Copy in Copy From Folder To Folder.vi->Librarian Copy.vi->ABAPI Dist Copy Non-VI Files.vi->ABAPI Dist Build LLB Image.vi->ABAPI Copy Files and Apply Settings.vi->EBEP_Invoke_Build_Engine.vi->EBUIP_Build_Invoke.vi->EBUIP_Build_Invoke.vi.ProxyCaller
Details:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1 occurred at ABAPI Dist Copy Non-VI Files.vi -> ABAPI Dist Build LLB Image.vi -> ABAPI Copy Files and Apply Settings.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488: Command requires GPIB Controller to be Controller-In-Charge.
(3,027 Views)
problem found: file group ID did not match that of the user. solved by fixing the group ID.
(2,979 Views)
Dear Cohen i.,
where do you change the group ID and what it is actually?
thanks,
Yogev.
(2,590 Views)
