Improve realtime prefomance.
I have a application that must always work with a maximum time delay of
100ms.
It works fine mostly but not as stable as I would like.
I have defined the process 'Time Critical'.
Is there any way to improve the real-time performance in WindowsNT?
Has Linux or Win98 better 'real-time' performance than Windows?
How much does a second processor help?
(3,990 Views)
> 100ms.
You will probably need to get Labview RT.
I dont know that a 2nd processor would help but it is possible
since some of the tasks can be offloaded. I do not know if
you are given a choice as to where a thread runs though.
Kevin
(3,990 Views)
Kevin B. Kent wrote in message
news:38FDD2D9.CF0DA8DF@usa.alcatel.com...
> > 100ms.
As well as changing the priority of the VI within Labview, you also have to
change the priority of Labview within the system- go to task manager, click
the "Processes" tab, find "labview.exe" and popup the right mouse button
menu over it. Under "set priority" you'll see "realtime" at the top of the
list.
Be warned though that setting a task to "realtime" means that task has
priority over most others and if your program cocks up, you're li
kely to be
locked out of NT and have to reboot. So save everything first 😉
(3,990 Views)
