In Cylinder Pressure measurement VI
I am currently working on a project where I have to create a Temperature and Pressure VI on LabVIEW using the Ricardo E6 Engine
Im reliably new too LabVIEW and I am just wondering if there is anyone who could help me with this ?
the equipment that have is;
-Kistler Type 7061B Piezoelectric pressure transducer
-K type thermocouple
-NI cDAQ-9178
-NI 9215 card for the pressure measurement
-Bruel & Kjaer Charge Amplifier type 2635
If anyone could give me some guidance this would be much appreciated.
Attached is what I have created so far, I have to sync the encoder in order to get the pressure data at TDC
(2,790 Views)
Hi Matthew,
Here are some steps we can try:
  1. Implement some error handling in the code (simple error handler, etc.). This will allow you to see if there is any error at run-time.
  2. When you install NI-DAQmx, you should be able to access DAQmx Examples on LabVIEW. To do so, please follow the instructions in the following knowledge base article: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004B6mSAE&l=en-US . In the search bar type Temperature and a project called Temperature Monitoring will pop up on top of the queue. Have a look at that and see if it helps.
  3. Same thing as above for pressure. It will give you the idea to build your application successfully.
Best,
Rob
(2,747 Views)
+1 for what RobGeografo wrote.
Please allow me additional comments in a different area:
- From the project overview you gave in your posting I don't get what exactly your final application shall look like. Do you need to acquire temperature and pressure in parallel? Do they need to by in sync?
- Your current code is a one-shot VI. Starting it it acquires data once, then stops. Maybe this is what you need, maybe not. Give us a hint (-:
- Your pressure sensor is connected to the NI-9215 DSA module. Where do you plan to connect the thermocouple?
- Your pressure task looks quite good. Please note that the 9215 can do 100kS/s. You have currently set the sample clock input to 200kHz. Not a problem, as you use your encoder output as sample clock, however this might be an indication that you expect like 200kHz as the encoder pulse frequency. Be aware.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(2,739 Views)
