ā05-02-2006 11:08 AM
ā05-02-2006 11:16 AM
ā05-03-2006 10:30 AM
thanks first!
According to your advice, i write a program in labview, but it cann't work correctly!
I attached a zip file including two file, one is lv file to read binary file that was saved by cvi,and another is cvi file that can generate binary file using arraytofile function.
I don't know where is wrong in lv file?
ā05-03-2006 10:57 AM
It has been a long while since I've used the file I/O operations in CVI but I'm confused about what you are doing there. You have the option to save as binary or ASCII and you are also setting the data type to double precision but in your VI you are attempting to read a U8 data type. Try changing your VI to match the data you are writing and attaching a sample of your file and a description of what it sould contain would be helpful.
And no, you do not need to do any casting of numbers to strings unless you want to display strings in your VI.
ā05-03-2006 10:50 PM
ā05-04-2006 08:45 AM
ā05-05-2006 09:30 AM
Hi Dennis Knutson:
do you mind giving me a example?!
I don't know how to do it about double type.
ā05-05-2006 09:41 AM
ā05-07-2006 09:24 AM
