In my LV 7.1 there is no palettes loop, print. Anything can do?
"Thanks with regards "
by
..........Gireesh..........
Message 1 of 11
(4,081 Views)
Hi Giresh,
what is a "palettes loop, print" exactly? What are you searching for?
Message 2 of 11
(4,071 Views)
I'm not sure what you are looking for.  However, at the top right corner of the palette, there is a search button.  Try searching for that function.
Message 3 of 11
(4,064 Views)
Are the palettes missing? Are just certain items missing? What happens if you right-click on an empty area of the diagram?
Message 4 of 11
(4,052 Views)
It is actually installation failure. Application builder also not installed due to failure. Once I send the log files to NI then they are told internal error. Installed with its orginal CD and tried with some other cd's also (copy). Is it available in the form of modules? Any other solution?
by
Message 5 of 11
(4,037 Views)
In the palettes window>all function>loops and print etc. This is blank
by
Message 6 of 11
(4,033 Views)
Can you post a screen capture?
I know you are referring to LV7.1, but from the Functins Palette, I have never heard of a section called "loops and print etc".  Unless it is a custom palette that you or someone created.
What is it that you are trying to do?  What function are you looking for?
Message 7 of 11
(4,014 Views)
19781iBFB77C05BBC8B72D
by
Message 8 of 11
(3,980 Views)
19783i88AADD51A33D75BA
by
Message 9 of 11
(3,974 Views)
Obviously, your LabVIEW installation is corrupted. Do you get an error during installation? What log files did you send to NI? What did NI suggest?
(1) Maybe you should also check your hard disk for errors.
(2) Do you run an updated antivirus. This could be due to some interaction with a virus or other malware.
(3) Maybe the CD is damaged. Where the copies you tried copies of the same, possibly bad, CD?
Have you tried copying the contents of the CD to a folder on the HD and installing from there?
Even if you manually could correct the menu, there are probably other things wrong with this installation or even with your computer. Is this the only LabVIEW version you have installed? Have you tried uninstalling completely, followed by a reinstall?
Message 10 of 11
(3,962 Views)
