In place element structure - Please explain
@RamonG wrote:
I know it was the wrong approach, it's one of those things you know you need to revisit but don't because there's never time to do so. My point was to warn against using primitives that you don't fully understand, just like I did.
Understood. Because that old discussion (that I missed) seemed poorly solved, I spent a few minutes implementing my suggestions and it is at least 40x faster on the first run, still giving identical results. See if it might help you in the future. Good look. We all keep learning! 😄
Message 11 of 12
(730 Views)
But why it is a dot shown at the array input in both cases? The one at the increment function in the first snippet is also strange.
Lucian
CLA
Message 12 of 12
(712 Views)
