In search of Projects based on Lab view.
    Iam Chaitanya, pursuing M.tech.. Iam using Lab VIEW,it is a good platform to work in realistic so I interested to do Lab VIEW projects. Can you please suggest projects based on Real-time applications or electronics.
(2,551 Views)
Hi Chaitanya,
                     In real time application you can go for the projects like dataloggers which having communications. Here all the operations on datalogger can be done using labview. You can plot the graphs, show the RTC, download and process flash & eeprom memory and so on.
Or you can go for TCP like projects where some equipments are sending data using TCP and you are reading that data using TCP tools in labview and write to database,excel and plot it later.
Its all depends on you what you want.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,512 Views)
Thank you very much for your suggestion, if you know any details regarding to electronics projects or any real time projects please give me the details.
(2,471 Views)
