In the attached VI I dont understand why data from the inner case structures are not being transmitted to the array.
Thank you! That worked.
Message 11 of 12
(357 Views)
Thank you both.   This is a pulled from a larger application. I took the actual VIs from the case structure to more easily see the problem.
Message 12 of 12
(353 Views)
