In which version of .NET FrameWork is compactable with Labview 2024 Q1
Hello
We are currently evaluating by using the free version of Labview 2024 Q1.
I have one question about in which version of .NET FrameWork is compatible with Labview 2024 Q1?
(For example, I want to use the Labview to adapt to the .Net FrameWork 4.0)
(1,744 Views)
AFAIK, nothing changed in LV24Q1 (VS much older LV versions, IIRC this changed between LV11 and LV12).
The manual mentions an assembly needs to be CLR 4.0 compatible: LabVIEW Programming Reference Manual, .NET - NI. With some modifications, this can be changed to CLR 2.0.
AFAIK, that's it for LV information.
I think this applies: How to: Configure an app to support .NET Framework 4 or later versions - .NET Framework | Microsoft ....
I think (but this is all a big mess) by default anything "Framework 4.x" should be fine.
(1,721 Views)
