Include Subdirectories in Build
I have a project with a few subdirectories that hold config files and header files the main program uses.
I have set these directories as "Always Include".
I have created teh directories in the "Destinations" section of the build properties
Under Source File Settings I have tries checking and unchecking "Set Destination for all contained items" to same as caller.
When I build it does not create the subdirectories and puts all the "alway include" files in the /Data directory.
=== Engineer Ambiguously ===
(3,054 Views)
Accepted by topic author RTSLVU
You have to set the destination of each configuration file individually.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,050 Views)
Ohhhh I see, it never dawned on me to do that...
Thanks!
(3,048 Views)
