Include full path with ZLIB
Hi there,
I've made a zip file using the OpenG ZLIB tools of a main folder with some subfolders (years) containing identical filenames (monthly files).
Something like:
Data\2006\April.dat
Data\2006\Mei.dat
Data\2006\Juni.dat
Data\2007\April.dat
Data\2007\Mei.dat
Data\2007\Juni.dat
(File names are month's in Dutch Smiley Indifferent)
The attached screenshot is the result of the zip file.
Only Filenames with no path, so I don't know from which year each file correspond and also I can't extract the files due to double filenames when extracting.
How do I include the full path in the ZIP file?
Any other suggestion as a work around are also welcome.
Thanks in advance!
Edit: Forgot this question
What's the difference between "File names" & "internal names (file name without path)" connectors?
I tried different connectios buth I never got the full path in the zip file Smiley Sad
Message Edited by Alain S on 08-23-2009 10:05 AM
Message 1 of 10
(7,027 Views)
Normally one would use the ZLIB Compress directory function for such a thing.
The internal path input is a (relative) path of the file inside the zip file, if you look at the ZLIB Compress Directory function you will notice that for every file, the base path is subtracted from the actual file path and that is used as the internal path.
For instance:
Dir to compress d:\data
File to compress d:\data\2009\augustus
Internal file name 2009\augustus
(more dutch names).
Veel succes,
Ton
My LabVIEW Ideas
Message 2 of 10
(7,002 Views)
Hi Ton,
Alvast bedankt voor je reactie Smiley Wink
After posting I continue some trials and also used the "ZLIB Compress directory" vi but it too has an annoying behavior Smiley Sad
Suppose I want to compress multiple folders into one ZIP file, something like:
C:\Program Files\App 1\File 1
C:\Program Files\App 1\File 2
C:\Program Files\App 1\Folder 1\File 11
D:\Data\File 11
D:\Data\File 12
D:\Data\Folder 11\File 111
I will end up with a zip file looking like
File 1
File 2
File 11
File 12
Folder 1\File 11
Folder 11\File 111
So, no way to know the original location of all files Smiley Sad
The only way to get the (almost) full path in the ZIP file is to first copy all folders into a Temp folder and zip that Temp folder since zipping
G:\TempZip\Program Files\App 1\File 1
G:\TempZip\Program Files\App 1\File 2
G:\TempZip\Program Files\App 1\Folder 1\File 11
G:\TempZip\Data\File 11
G:\TempZip\Data\File 12
G:\TempZip\Data\Folder 11\File 111
result in a zip file looking like
Data\File 11
Data\File 12
Any idea why the ZLIB library subtract the base path?
Why not using the whole path?
If I'm not mistaken the original ZIP program had the ability to store the whole path, even with drive name, so one could restore all data in the original location. With the ZLIB library one can't do that.
Regards
Alain
Message 3 of 10
(6,983 Views)
Hi Alain,
Alain S wrote:
Hi Ton,
Regards
Alain
I wouldn't know how a zip file could contain a drive path as well, it would be very weid to extact such a file on a different computer (or even OS).
Removing the base path is the thing  that looks 'correct' to me, perhaps it is an idea to add an input to the VI that is similar to the internal name for normal files.
Ton
My LabVIEW Ideas
Message 4 of 10
(6,977 Views)
You are right Ton !
No drive path in the full path of good old ZIP program. I was mistaken 😞
But it had the choice between full or relative path so I felt free to modify the "ZLIB compress directory" so that the user has the choice between Absolute or Relative path.
It was easier to do than I thought Smiley Very Happy
Unless I overlooked something :smiley-sad:
Relative path:
Absolute path
Equal changes shoulde be made in the "ZLIB Compress files" vi, but that's for later 🙂
Message 5 of 10
(6,958 Views)
Well the ZLIB Compress Directory has to do something and most compress utilities will take the longest common path for all files as starting point. No need to include 10 levels deep of directory hierarchy if all files have that.
The right solution would be to make a variant of this called ZLIB Compress Directories, that takes an array of starting directories and then interactively works on each of them to do what ZLIB Compress Directory does. Or otherwise modify the ZLIB Compress Directory to use the "append to archive" method when opening the archive the second and all successive times, each time with another base path. The proposed solution to include the entire path sounds like a big hack to me, and I will not add that to the library.
Rolf Kalbermatter
Message Edited by rolfk on 08-24-2009 08:40 PM
Rolf Kalbermatter  My Blog
Message 6 of 10
(6,952 Views)
rolfk wrote:
... ... that takes an array of starting directories and then interactively works on each of them to do what ZLIB Compress Directory does. Or otherwise modify the ZLIB Compress Directory to use the "append to archive" method when opening the archive the second and all successive times, each time with another base path.
That is exactly what my calling vi does, run through an array of directories on different locations/drives Smiley Surprised
How come you know what I'm doing???Smiley Very Happy
Don't need to modify the ZLIB Compress Directory vi to use the "append to archive" stuff. In the loop of the calling vi use the loop counter to connect "create new" when it's equal to 0 or "append to archive" in other cases, to the "append (create new)" connector.
I don't see what's the problem here, the original ZIP program has this possibilty so, what's the problem??Smiley Indifferent??
The idea is that the user knows the original location of all files. When using those vi's to make a backup/archive-like application one would be interested to know the whole path (except drive letter) so that when the files needs to be restored, the complete, correct folder can be created.
Message 7 of 10
(6,942 Views)
My bad, it's been some time that I worked on that library, and I wasn't exactly sure if this parameter was exposed by that VI. Smiley Wink
Well for one thing I did not want to write a pkzip replacement Smiley Tongue. Instead I wanted to write a library that allows to distribute LabVIEW code. This library is at the core of the OpenG package format, which is used by the OpenG Commander and its professional successor VIPM.
And the library is as it is already quite big, has already many more or less complex options, but as you have found out is still very easy to adapt to whatever you want to do if you dig a little into its workings. Smiley Very Happy
Rolf Kalbermatter
Message Edited by rolfk on 08-25-2009 08:36 AM
Message 8 of 10
(6,934 Views)
Hi Rolf,
what about this idea:
This gives a user the oppertunity to place the directory inside a folder in the archive.
Ton
Message Edited by TonP on 25-08-2009 09:51 AM
My LabVIEW Ideas
Message 9 of 10
(6,926 Views)
It would be a possibility except for two reasons:
1) The ZLIB Compress Directory connector pane is already quite full.
2) and more important because of this remark in the diagram: "ZIP files should also contain a file entry for each subdirectory they contain, but not for the '.' dir"! So there would be additional work to be done here.
Rolf Kalbermatter
Message 10 of 10
(6,921 Views)
