Including ActiveX Class
I have doubt in how to add the required activeX Class for the excel object through the browse option.
I raise this question because initially i created this excel application constant from the automation open function. At that time i when i right clicked for the select ActiveX class option it was showing only two options like Excel.Range and Excel._Application.
After going through the examples in the forum i found the same constant has other option as shown in the figure (Excel._workbook and excel.Sheets) when the select ActiveX class option is right clicked.
So how can we browse and select the required option by our self.
(3,670 Views)
You must choose select Active X class\browse\Microsoft excel object library version..\workbooks collections or something else.
(3,640 Views)
Asking a complex question, particularly one involving non-NI software (ActiveX, Excel) without showing it in its LabVIEW context and in a "Forum-friendly" format (which means "as a VI or an entire LabVIEW Project, zipped up by compressing the entire Project folder", not as a static "look-at-me" image) doesn't give us much to go on.  I use Excel together with LabVIEW in several ways, including (occasionally) ActiveX, but have no idea what you need.
Bob Schor
(3,626 Views)
