Including DLLs in a PPL as a relative path
I have very similar issue, but with "exe" file being a part of lvlib (and lvlibp). Did you find a good solution of workaround?
Message 11 of 13
(692 Views)
matowc, unfortunately not. The only option is to remove non-LabVIEW files from the library and manually include them in the build specification. But this still doesn't solve the problem of having the non-LabVIEW files automatically included when referenced by another library or executable - you'd have to remember to manually include them in their build specs as well.
Message 12 of 13
(671 Views)
matt.baket, thanks for reply. That's the way I do it, I hoped that maybe you've found something better 🙂
Message 13 of 13
(651 Views)
