Including the browse button in the tabbing order
I am setting up a configuration dialog when my vi opens.  All fields are included in the tabbing order, however, when I get to the file picker, I am unable to activate the browse button using the keyboard.  Is there a setting for this or a way to include it in the tabbing order for when a mouse is not available?
To be clear, the cursor enters the file path field and I can type in there, but I can not get it to focus on the browse button.
Any help would be appreciated.
Message 1 of 11
(4,216 Views)
That's a good question.  I don't see where you can get a reference to the browse button. (LV2012)
You could turn off the browse button associated with the file path control and make your own button that will popup a browse window.
aputman
Message 2 of 11
(4,192 Views)
Accepted by topic author jprukus75
Create a separate button to replace the built-in button.
George Zou
Message 3 of 11
(4,184 Views)
Thank you.  I knew this was an option, but was hoping there was a built in way to do it.
Message 4 of 11
(4,178 Views)
Or you can use a custom run-time menu with Ctrl+O shortcut.
The keyboard shortcut will work even if the menu is hidden.
George Zou
Message 5 of 11
(4,163 Views)
Although I was able to get a reference to the Browse button and mess with its properties, I couldn't get it to take focus when tabbing, nor could I set toggle key binding for it.
Message 6 of 11
(4,155 Views)
How did you get a reference to it?  Is that something added in later versions?  If you can do that, you could tab into the path control, hit Enter (or some other key) and use a key down event to toggle the button.
aputman
Message 7 of 11
(4,151 Views)
I used the Selection Change Event:
Then when I click on the Browse button (in edit mode), "SelList" spits out the reference.
I don't know a non-interactive way to get a reference to the Browse button.
Message 8 of 11
(4,145 Views)
Will this help?
Message 9 of 11
(4,140 Views)
Message 10 of 11
(4,137 Views)
