Incomplete simulated device list in MAX
I'm trying to create a simulated device (PXI-4071 DMM) using NI-DAQmx 8.9.5 but the list of instruments (see attached picture) contains far less than the list shown in the "NI-DAQmx Simulated Devices" tutorial.  Most specifically, it doesn't contain the category "Digital Multimeters" where I'd expect to find the PXI-4071.  What drives the list of available instruments?  Are there device drivers I need to load to fill out the rest of the list?
-Warren
(2,999 Views)
Install the latest DAQmx drivers.  I am running 9.2.3 and it shows up.
(2,992 Views)
Accepted by topic author kayotik0987
A DMM does not use DAQmx so that is why you would not see it listed. You use NI-DMM and it can be simulated if you use the IVI driver.
Edit:
"Install the latest DAQmx drivers.  I am running 9.2.3 and it shows up."
You are correct. Never saw that before.
(2,991 Views)
I just checked and I have NI-DMM installed as well.  So I would guess it gets added when the DMM software is installed because it is not listed in the 9.2.3 readme as being supported.
(2,978 Views)
