Inconsistent Reading
We are using the FCO510 to measure injector flow rate, however, when I took a measurement recently, the "master" injector did not have the same reading from it's previous data, around 50 l/h variance in reading. Tried troubleshooting for leaks and cut some festo tubings as it might have worn out..have a go again with the master injector but still with the same low reading from its previous data. not sure how to troubleshoot it this time.
(2,585 Views)
Does your question have anything to do with LabVIEW? Please explain?
(2,557 Views)
