Incorrect Channel Names
I am using LabView 6.0 and MAX 2.0.3.6 with Windows 2000. When I use the "Get DAQ Channel Names" vi, the channels come back in the wrong order (PCI-6033 board). They are correct in MAX. I've tried setting the path for the niconfig.daq file but that did not work. Clues?
(2,719 Views)
Using "Get DAQ Channel Names" vi will return the channels in the order they were created, not alphabetically as they are displayed in MAX.
Good luck with your application.
(2,719 Views)
