Incorrect Read Buffer string from VISA Read
I am having some issues with my VI. I have a MARK-10 deflection test stand that I send text codes to the gauge and ram. In the "Get Reading" Case, when I send the "X" to retrieve the gauge reading, I can't pull the correct reading from the gauge. I instead receive the ram status which, in the previous Case Statement (Test Sample) is a "n".
The "code" acts like it doesn't fully flush the buffer. Even after I try the VISA Clear or VISA Flush items, I still receive the ram status.
It's driving me insane! Anyone have ANY ideas without rewriting the whole thing?
Eric
(4,025 Views)
Are you sure you don't need carriage return or line-feed characters to terminate your commands?
(4,016 Views)
No, I can read everything OK up to that point.
(4,009 Views)
I've found the solution to my problem. I replaced the VISA Clear with the VISA Flush command at the end of the Test Sample Case. Not quite sure why that worked. I was under the impression that they were the same???
(4,004 Views)
Hi Eric1977,
VISA Clear and VISA Flush I/O Buffer are not the same. LabVIEw help states:
VISA Clear Function: "Clears the input and output buffers of the device."
VISA Flush I/O Buffer Function: "Flushes the I/O buffer specified by mask."
Basically, VISA Clear will erase the information from the buffer, with VISA Flush you are acquiring the remaining data from the buffer. So, I think you were deleting the data before using it.
Jorge
Certified LabVIEW Associate Developer (CLAD)
(3,970 Views)
