Incorrect amout of samples in TDMS-File
I have an odd issue.
When I'm setting the sampling rate to 4kHz (dt = 0.25ms) and 1000 samples I expect to get 40000 samples in the tdms-file within 10 seconds.
But I'm getting less values.
When I set the sampling rate to 5kHz (dt = 0.2ms) and 1000 samples I'm getting the expexted 50000 samples in the tdms-file.
So I guess this comes from the 5th digit of dt. When it's not 0 daqmx messes up.
Does anyone also had this experience or has a workaround?
Thanks for any help.
(2,233 Views)
Accepted by topic author Yves
It could depend on how you generate the data.
If you sample blocks, and time with software, you might get a block or not depending on how exectly you're timing.
You might get a modulus of the nr. of blocks, ignoring the remainder. If the rate amounds to an exact number of qoutients, the remainder is 0. If not, you get less samples than expected.
I suppose you thought about this, but without knowledge about how the TDMS is generated, we can't be sure.
(2,215 Views)
Hi Yves,
Which DAQ hardware do you use?
Did you check the samplerate the DAQmx task is really using?
Not all DAQ hardware supports ALL sample rates, some devices are limited to just 16 or 32 different sample rates based on a certain main clock: 5kHz can be derived from 50kHz main clock with a divider of 10, while 4kHz cannot derived using an integer divider!
(2,201 Views)
