Incorrect display format using for-loop
I have a numerical array using an hexadecimal display format that is autoindexed by a for-loop. Within the for-loop each single value is passed to a sub-VI that needs the hexadecimal display format. Unfortunately, the indexing doesn't keep this hex-format but transfers it back to a decimal format.
Any idea how to solve this?
Thank you in advance and best regards
Simon
(3,806 Views)
The formatting is a cosmetic property of the control or indicator. The value is independent of the formatting. If you want to display a value in hex format, all you need to do is change the display format of that particular front panel element.
(If the subVI requires a different datatype (e.g. binary string or hexadecimal formatted string), you need to give us more detail. What does the subVI do? Can you show the subVI too?)
(3,795 Views)
The subVI reads values from a plc using adsocx. It needs an indexgroup value and an indexoffset value both of them as a numerical values in hexadecimal format.
Attached you find a subVI to read integer values.
(3,783 Views)
Both inputs are just plain I32 numerics. The display format is irrelevant for this.
(3,735 Views)
Accepted by topic author simon-b
Thank you for this hint. The problem was another subVI where I created the num-array which afterwards goes in the for-loop. There, all numerical elements where set to I16 instead of I32. The plc could not handle these wrong values, thus I got nonsense.
Thank you for your quick replies!
(3,686 Views)
