Incorrect syntax near the keyword 'where' in NI_Database_API.lvlib
I'm trying to connect to SQL Data Base using provided .udl file.
I tested .udl file using "Test Connection" button and the connection is successfull.
My Code is attached.
I get error:
NI_Database_API.lvlib:Conn Execute.vi->NI_Database_API.lvlib:DB Tools List Columns.vi->Untitled 2<ERR>ADO Error: 0x80040E14
Exception occured in Microsoft OLE DB Provider for SQL Server: Incorrect syntax near the keyword 'where'. in NI_Database_API.lvlib:Conn Execute.vi->NI_Database_API.lvlib:DB Tools List Columns.vi->Untitled 2
(3,268 Views)
I get the same error when I input a null string as table name to DB Tools List Columns vi.
Are you sure that index is in range? What's the table name?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,262 Views)
