Increase Decrease (again)
Hi!
Earlier I got some great help with my program. I'm using a quadrature encoder to measure a motors rotation velocity. Since I couln't get anything else to work, I'm sampling the inputs from the rotary encoder with analog inputs, wich seems to work fine. I get one LED to lit when the motor runs in one direction, and anotherone to lit when the motor is rotating the different way. Now I just need to count the pulses: +1 for each time pulse in one direction, and -1 for each pulse the other way.
I believe that the problem explains itself the best in my attached VI. Hope anyone can be helpful with my big (but simple I guess) problem 🙂
(3,187 Views)
Hi Kristoffer,
use one more shift register... And cleanup your code Smiley Wink
Message Edited by GerdW on 04-15-2008 08:46 PM
(3,182 Views)
Tanks 🙂
Unfortunately, this doesn't solve the problem. Problem now is that the program adds one number  w h i l e  the pulse is high. If the pulse is long enough the program can add for instance 50 numbers pr pulse. Each time I've got an incoming pulse, I just need ONE increment /decrement.
But thanks a lot for your time, and thank you for your tups on cleaning up my code. Of course you've already understood that I'm a really rookie to LabView 🙂
(3,179 Views)
Hi Kristoffer,
you didn't mention before that you only want to count rising edges...
See attachment! (I'm sure the boolean calculations can be simplified even more now...)
(3,162 Views)
I guess I didn't write that, sorry about that.
And thanks a lot! You really saved the day! Now, as soon as I find out how to rate a good answer I'll give you an A+
THANKS 😄
(3,160 Views)
