Increase SQLite Write Speed
I have a VI that's writing data to disk from an FPGA. Unfortunatly, My SQLite writer is having difficulty keeping up with the write speed and I would like to know if there is anything I can do to keep up. Currently, I'm able to write 10,000 rows in 60ms. I would love to get down to 30ms or faster if possible.
To write the data, I have the following steps:
  • Read FPGA data as a 2D array in a producer loop, pass as variant to consumer loop process state (time start, t=0)
  • Convert 2D array to 1D array of clusters (to better represent "real data,"), run a fast check and pass as variant to logging state (5ms, t=5ms)
  • Log 1D array of clusters (as=10,000) with drjdpowell's SQLite library (60ms, t=65ms )
Please take a look at this simplified VI to see if there's anything I can do.
Message 1 of 10
(6,437 Views)
You can try to form one request into one large string:
INSERT INTO table1 (column1,column2 ,..)
VALUES
(value1,value2 ,...),
(value1,value2 ,...);
Or you need a faster HDD 🙂
How long do you plan to write this data? If not for a long time, then perhaps you can accumulate data in memory, and writing them down after reading.
Message 2 of 10
(6,401 Views)
Unfortunately, we're taking data over a few days so we can't just buffer to memory.
I tried the bulk data you mentioned and it seems my performance decreased from 60 to 100ms.
Updated VI below
Message 3 of 10
(6,394 Views)
Also, In terms of getting a faster hard drive, we're using an SSD and writing at about 500kb (currently over 60ms) for 8.3Mb/s As I understood it, SSD's can write in the 100's of megabytes.
Message 4 of 10
(6,390 Views)
Measure the write speed of a binary file.
And a workaround for solving the problem is to write a binary file, and after the experiment, transfer it to the database.
Message 5 of 10
(6,370 Views)
Accepted by topic author JScherer
PRAGMA synchronous:
0 | OFF
1 | NORMAL
2 | FULL
PRAGMA temp_store:
0 | DEFAULT
1 | FILE
2 | MEMORY
Use:
PRAGMA synchronous = 0
PRAGMA temp_store = 2
But be careful, this is a quick but not safe way to speed up.
Message 6 of 10
(6,346 Views)
@IvanLis wrote:
PRAGMA synchronous:
0 | OFF
1 | NORMAL
2 | FULL
PRAGMA temp_store:
0 | DEFAULT
1 | FILE
2 | MEMORY
Use:
Thanks!
With these changes I went down from an average of 60ms to 35ms write speed.
FYI: Trying the binary write, got me 12ms, so if this continues to be an issue, I can do the raw file with a separate conversion utility.
Message 7 of 10
(6,317 Views)
You seem to have gotten the speed that you want, but I'll say what I first thought of anyway.
Your VI that writes a row of data, call it asynchronously and enable re-entrant execution so multiple rows can be written simultaneously.
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 8 of 10
(6,307 Views)
I'll have to test that out if I run into the issue again. I'm concerned about having multiple writers to the same file though, but I suppose with unique transaction IDs for each Async call would mitigate.
Message 9 of 10
(6,294 Views)
I would recommend using Bynary TDMS.
The access speed is actually the same, but it is much easier to organize data writing and reading.
Message 10 of 10
(6,283 Views)
