Increase in Loading time for LV search in 2011
Initially when I loaded LV2011 my quick drop and the search took nearly 5 seconds but now it takes nearly 20 seconds to load so is there any reason for this kind of performance. Also I don't have anyother big software loaded or running in my PC. I have added few toolkits from VI package manager may be that is the reason?.
(2,818 Views)
did you add some toolkits? FPGA, RT, Vision builder,....  [Edit: OK - I can read-  you did add TKs]
How are your ini settings for loading palattes?  (Load during launch- launch might mean "goto lunch" if you have a billion toolkits but QD and Search will speed up.)
(2,814 Views)
In my message in the other thread, I commented that I thought 20 seconds wasn't all that long.  But I thought you were commenting on the loading time for LabVIEW itself.  That does seem like a long time for any of the internal LabVIEW dialogs to come up.
(Actually, I find several internal dialogs seem to take longer to load the first time then they should including the properties dialog.  But not 20 seconds long.)
Hopefully, with this message thread in the LabVIEW forum, others can comment and offer suggestions on how to determine what the issue your having is.
(2,811 Views)
I am not sure about that setting. Could you please tell me which one in the LabVIEW.ini?
(2,810 Views)
tools>>optionsSmiley Wink
(2,804 Views)
Yes now I have plenty of toolkits ( Thanks for spotting me in the other thread )
Jeff you hit the bullseye. The loading was set as Load palette when needed.
(2,800 Views)
Yeah the Quick drop adds all vi's in memory and in palettes, user- and vi-lib, so add-ons will increase that time.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,788 Views)
