Increase the width of numeric array constant
I am using a type def data structure that is an array of a cluster of numeric controls.  When this structure is placed on the block diagram as a constant, the numeric values appear about 1 digit wide.  In order to see multidigit values, the numeric constants have to be widened.  This can be done by manually stretching each numeric on the block diagram, but this can be quite laborious if there are many numerics in the structure and any time that the type def is changed, the numerics change back to 1 digit wide.  Is there an easier way to make the numerics either keep a wider size or autosize to their contents?  Numeric constants autosize if they are not inside an array, but in the array they are narrow.
(2,634 Views)
(2,629 Views)
