Increasing Execution Speed
I am using 3 digital channels on Picoscope. Two of them receive the trigger TTL signals. One channel is for single events signal.
So, when I split these channels, the rest of the code is doing the same kind of things as before.
I have a search for the low frequency trigger.
After, I create two different outputs depending on the fact whether the low frequency trigger is found. So, I have the case structure with almost the same codes. In both cases, to create these outputs I search for the position of the high frequency trigger.
 Based on the position of these trigger I cut the part of the single event array (first bit).
And I sum up these data  
I need exactly this data . The experiment could be very long. So, it is not an option to save the data first and than to process it.
I completely agree that is seems to be a waste to use I16 for a single bit and that could be the reason why the code is not that fast as it could be. However, I do not know right now any better way. Could you advice anything?
Message 31 of 31
(600 Views)
