Increasing Maximum Step Time in LabVIEW for BK PRECISION 8514b Load in List Mode
I am controlling a BK PRECISION 8514b electronic load using LabVIEW. The communication and all control modes (CC, CV, etc.) work fine. However, I have an issue with the List mode:
  • When using manual operation, the maximum duration for a step is 3600 seconds (1 hour).
  • Through LabVIEW, the Step Time parameter in the Configure List Step Parameters block is limited to a maximum of 6000 ms (6 seconds).
I would like to know: how can I modify the block or configuration to increase the Step Time beyond this limit?
Thank you for your help!
Message 1 of 1
(570 Views)
