Increment +1 after Boolean toggle
Trying to increment +1 after Boolean variable toggle.
It should be simple but I got stuck because I need to increment when 1 goes 0 and 0 goes to 1.
Like detects the edge of pulse.
Jo
Message 1 of 9
(2,352 Views)
You don't have a lot of details here but it kind of sounds like you need to add an event structure, with a "value change" event on a Boolean control, but with no other context to go on it could be something else that you need.
Message 2 of 9
(2,337 Views)
See Counter and Digital Edge Detector
There is a mistake in the falling edge loop. The constant should start with a false.
https://tmesystems.net/
Message 3 of 9
(2,299 Views)
You can use a feedback node to compare current to previous. If the are not equal, add one to the counter.
Quick draft:
Message 4 of 9
(2,289 Views)
What is the source of the Boolean?
If it's hardware, you probably want a anti jitter strategy.
If it's a UI, you probably want to use an event structure
Message 5 of 9
(2,272 Views)
You can use the built-in Is Value Changed primitive, or any or it's variants, like the one supplied with the OpenG toolkit. There are differences, namely whether the first value received by the VI returns a True (NI's correctly does, OpenG's does not).
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 6 of 9
(2,241 Views)
Sorry i didnt realized that more detailed explanation was needed.
I m reading Temp from the sensor.  Temperature is going thru cycles, up and down.
Have a threshold that produces Boolean output.
Measuring time for True and False cycle.
Writing times for each cycle to array.  Thats why I need increment.
I start looking to event structure, but I never did it before.  Because examples might not work for this case.
Hope this clarifies the need.
Jo
Message 7 of 9
(2,136 Views)
Jo
Message 8 of 9
(2,135 Views)
Using the Boolean crossing point by point from the signal processing palette (ptbypt, other functions).
Here I'm using a threshold of 0.5 and using the either direction setting.
Ben
Message 9 of 9
(2,127 Views)
