10-01-2007 02:31 PM
10-02-2007 10:05 AM
10-02-2007 11:04 AM
10-02-2007 11:08 AM
I made a mistake is my earlier reply, this IS A STANDARD CONTROL. I also called the NI help line and they were able to confirm that the increment and decrement button check box for a menu ring control are greyed out.
Kaspar
10-02-2007 11:54 AM
10-02-2007 12:37 PM
Thanks for getting back to me. the controls are greyed out because they do not exist on the Menu ring control. This is different from what I saw in another part of this forum about using event structures on a Menu ring.
Thanks again
Kaspar
10-03-2007 09:05 AM
Errr... yes, I believe that's exactly what I said in my last response.
"the controls are greyed out because they do not exist on the Menu ring control."
Don't know what you could be referring to, as there is no event specific to the increment/decrement controls. All that they would do (if they existed) is to change the value of the control, and the applicable event would be the "Value changed" event. Where exactly did you read this?
"This is different from what I saw in another part of this forum about using event structures on a Menu ring."
