Increment/decrement button
Hi all,
can you adapt increment/decrement button to change (increment or decrement) the last siginificant digit?
For example, if I have 0,0001 I want that increment button changes the value on 0,0002, not to 1,0001.
Kristina.
(4,643 Views)
Hi Kristina,
this is already implemented since a long time ago...
- Go to 'Data Entry'
- Uncheck 'Use Default Limits'
- Set 'increment' to the desired value
(default = 0.00000 which increments by 1.000 if no cursor is present OR increments the digit just before the active cursor).
(4,637 Views)
Edit: Already answered
(4,606 Views)
